Hub setting pop-ups large font. Affecting menu
1982
12-03-2021 07:01 AM
Jessh0972
Really wasn't sure what title to give this issue.
The text which pops up when I try to format or delete items in my Hub layout is really large:
I think the same issue is affecting the main site menu for mobile users:
I have applied a custom font to the site, and set font sizes for headers in the HTML of a text box as below:
<style>
header{
font-size: 60pt;
color: #000000;
h1{
font-size: 48pt;
color: #000000;
h2{
font-size: 36pt
color: #000000;
h3{
font-size: 24pt
color: #000000;
h4{
font-size: 16pt
color: #000000;
ul{
font-size: 16pt
color: #000000;
li{
font-size: 16pt
color: #000000;
</style>
Could this be causing the issue? The large pop-ups as I'm editing the sites aren't a huge concern, but the menu links for mobile users really need fixing.
Any help appreciated.
KlaraSchmitt
Hello,
Typically, we discourage use of generic CSS selectors in custom CSS as it can have unwanted side-effects on the actual layout application, which also uses headings, ul, and li elements and might be getting caught up in a cascade effect. Ideally, you'd want to wrap any Text Cards with custom styles in a unique class (you can do this in row settings) and then you'd prepend the row class as a unique selector in front of your generic selectors. Maybe you could give that a try on one of your affected sections?
DataOfficer
I don't have an answer but could it be related to the recent update?
https://community.esri.com/t5/arcgis-hub-blog/faq-upcoming-changes-to-base-font-size-and-rem/ba-p/10....
Jessh0972
I also wondered this. But I haven't used rem anywhere in my site and the two things being affected (delete pop ups and mobile menus) aren't things I know how to access the code or settings for?
I just checked an old Hub site and that doesn't seem to be having the same issues, even after the update.
KlaraSchmitt
Hello,
Jessh0972
That's the ticket! I was unknowingly making my own life difficult.
Thanks so much
