How to activate map visualization on fields in ArcGIS Hub ?
890
05-07-2020 03:30 PM
JoanneTallon2
The map visualization functionality seems activated on my feature Layer but it's not available on any field.
I have fields with less than 20 values. Should I activate anything else?
ThomasHervey1
Esri Alum
Hi Joanne Tallon
This may be unexpected behavior. Do other Feature Layers on your site show a map? When you select different attributes, does a map appear? If your data is public it would be helpful to share a link to the dataset.
