Embedding Instagram into ArcGIS Hub
1887
02-22-2024 08:40 AM
Bahare_Sanaie
I'm wondering if anyone has successfully embedded an Instagram public page into ArcGIS Hub. It seems the link isn't accepted directly.
Has anyone encountered this and found a solution? Your insights would be greatly appreciated!
AlexanderDanielPratama
Currently based on Esri's documentation only Facebook and Twitter support in Hub
Embed video, social media, and iframes—ArcGIS Hub | Documentation
Another untested solution is probably you need to create a simple HTML dan embed an Instagram post then use the HTML that you created to embed in Hub.
Hope, it helps you
Cheers
EvelynneEthelreda
    • Identify the Instagram posts or content you want to embed into your ArcGIS Hub project. You might want to search for posts related to specific locations, events, or themes relevant to your mapping project.
  1. Obtain Instagram Embed Code:
    • Once you've found the Instagram content you want to include, obtain the embed code provided by Instagram for each post Instaup apk. To do this, navigate to the post on the Instagram website or app, click on the three dots (...) at the top right corner of the post, and select "Embed". Copy the embed code provided.
jamessergent
Hello Esri Community,
I ran into the same issue while working with ArcGIS Hub — Instagram public page links usually aren’t accepted directly because of Hub’s embed security restrictions and Instagram’s iframe limitations. A workaround that helped was using a third-party Instagram widget or embed generator, then placing the generated HTML inside a custom embed card in ArcGIS Hub. It’s not perfect, but it does the job smoothly for public feeds. Also, while searching for simple media tools, I came across Honista which some people use as a free streaming/downloading app companion for Instagram content management.
Thank u!
