A user experienced an issue that was solved in 2020: text cursor jumps to beginning of text block
1327
03-02-2023 10:20 AM
Josh-ENVGIS
A user of ours experienced an issue that has a solution listed, here: https://community.esri.com/t5/arcgis-hub-questions/while-typing-text-cursor-keeps-jumping-to-the-top...
The user reports that when editing text on a Hub Site, after every keystroke the cursor jumps to the beginning of the text box. The issue does not occur when using the Edit in HTML option, so there is an easy workaround, however I'm not certain of the solution based on the resolved post, linked-above. Is there a solution on our end? If not, it seemed worth mentioning.
Josh-ENVGIS
beep boop, no response 😕
NancyBellegarde1
I'm still having this issue..
Josh-ENVGIS
We are still experiencing the issue as well, thank you for replying, Nancy.
