Which model is better in GA?
4075
05-25-2013 10:31 PM
Chia_HsunLee
im using GA to deal with raining data, and so confused on the rule to choose the better model
Rule1
in the book, it said you need choose a model to FIT your semivariogram points
Rule2
in the HELP CENTER, it said smaller Root-Mean-Square , nearest between Root-Mean-Square and Average Standard Error , and
make Root-Mean-Square standardized equal to 1
BUT i got 2 different model results under these 2 rule
Result1 , the model seems very close to the semivariogram trend , but its Statistical property is not obey Rule2
[ATTACH=CONFIG]24678[/ATTACH]
Result2,  its Statistical property is exactly accurate on Rule2 , but the model line seems not fit the trend of semivariogram points
[ATTACH=CONFIG]24679[/ATTACH]
so , which one is the "better" model i can use?
or how can i modified to satisified these 2 rules
EricKrause
This is a tough call.  Both rules are important, but I tend to give more preference to crossvalidation.  However, since you have one model with a perfect visual fit and another model with perfect crossvalidation, I think you can find a third model that has both.  Try using Spherical and K-Bessel semivariograms.
by Anonymous User
Not applicable
Original User: van6499
haha very thx
now i found the 3rd model , and got a beautiful result~
