where is the view settings panel in the geostatistical wizard for semivariogram?
6139
5
12-05-2013 11:07 AM
annfeng1
I don't see the view settings or the export option as illustrated here http://resources.arcgis.com/en/help/main/10.1/index.html#//0031000000n4000000
The only available panels are named general, model nugget, model#1, 2, 3, lag etc. How can i access the settings for semivariogram plotting? Thanks in advance for any pointers!
SteveLynch
Please share a screenshot or try and see if you can resize the window that should be above the horizontal line above the 4 buttons on the left. See image below.
[ATTACH=CONFIG]29627[/ATTACH]
annfeng1
I attached the screenshot. Although mine is Arc 10.0 but the help documentation regarding view settings in semivariogram is identical to that of 10.2 so there should be a view settings tab. I am puzzled as to where it is. I have editor license as well. Thx,
[ATTACH=CONFIG]29630[/ATTACH]
SteveLynch
Vertical line in your case, see below
[ATTACH=CONFIG]29632[/ATTACH]
annfeng1
thanks a lot for your tip. Yes double click the pointed area solved the mystry of the elusive tab. I can't seem to delete the attached image which is no longer necessary. can you help me remove it? thanks
EricKrause
We'd prefer to leave these attachments up in case someone else has this problem.
