Temperature: finer regular network -> conservative & smooth surface.
3155
05-19-2013 02:05 AM
by Anonymous User
Not applicable
Original User: synaps
Hi, guys.
I have an average monthly temperatures in 25km regular network. I need to interpolate this data, making it smooth but conservative (with contours passing through as many as possible point values). Now my surface looks very sharp...
Do I need to use bilinear interpolation (or any other tool) to make my network finer and only then to interpolate my values?
Or I need something like radial basis function (with spline-tension kernel) / kernel smoothing interpolation method?
Any tips on this type of data would be appreciate.
[ATTACH=CONFIG]24478[/ATTACH][ATTACH=CONFIG]24479[/ATTACH]
by Anonymous User
Not applicable
Original User: stevelynch
To change the way that the raster is rendered you can try:
- right click on the raster layer in the TOC
- choose Properties
- on the Display tab, change the "Resample during display using:" to Bilinear
- Hit OK
-Steve
