Raster Spatial resolution
3512
6
03-20-2013 02:20 PM
swatantrakethireddy
I have produced a GA layer from Point data of an air pollutant by using ordinary kriging method.
I am trying to convert it to Raster format and to understand the spatial resolution of produced pollution map. Out put cell size is giving this quantity 2.22146629822742E-02 in the tool window..I want to know the spatial resolution in either meters or kilometers. If i want a 1 kilometer resolution map. what is the method to produce?
Please help me.
Thank you
Swat
EricKrause
The cell size is measured in map units.  To determine your map unit, hover over the map and look at the bottom right corner.  If it isn't in meters, you'll need to do a unit conversion (for example, if it is in kilometers, you'll want a cell size of .001).  If it is in Decimal Degrees (lat-long), you'll have to project your data because there is no direct unit conversion from decimal degrees to meters.
swatantrakethireddy
Thank you very much Mr. Eric
swatantrakethireddy
Hi Mr. Eric,
I have Projected the data, the map units are in meters, and now i have produced a raster map.
But the produced map has minimum and maximum values different from the original GA layer and source data. To resolve it, I tried it by increasing and decreasing the cell size in raster tool window. But it does not work. What can i do now?
Thank you
SteveLynch
Please have a look at some of the Geostatistical Analyst blogs, in particular
http://blogs.esri.com/esri/arcgis/2008/09/29/understanding-geostatistical-analyst-layers/
-Steve
EricKrause
If you're still confused after reading that blog, try reading this forum thread:
http://forums.arcgis.com/threads/77248-kriging-results-to-raster
swatantrakethireddy
Thanks for your timely replies.
