raster data as service
1606
10-22-2012 03:51 AM
NadeemQazi
Hi there
I have used  Kernel Density tool from the spatial analyst tool on one of my layer in the map document. the result i assume is generated as raster data.on the ARCMAp i used identify tool to find the density at any point. However I wan to do the same job from  client side using browser.I  plan to use identify task from the client. My  query should i publish my map as MAP service or is there any other service i need to use for accessing identify task from client.
NAdeem
