Ordinary Kriging Question
7635
10
04-10-2012 11:26 PM
RyanWhitehouse
I'm a graduate student working on a project that involves well points, each associated with a measure of nitrate. I also have HUC10 watershed delineations, which I plan to use to breakdown the data later. I ran ordinary kriging through the Geostatistical Analyst using the nitrate well points and choose the Gaussian model. I ran into two problems here:
1) The kriging output did not automatically format itself as a raster dataset. Instead, I had to convert it, but by doing so it distorted the surface. Is this normal? I tried kriging via the toolbox, and it seemed to have converted it just fine. Does this mean I can't use the Geostatistical Analyst?
2) When I ran zonal statistics on the interpolated raster surface, using the HUC10 as the zone layer, the ArcToolBox would crash. This happens on multiple computers at different locations. Is there a way to get around this?
Basically, I'm trying to do a hotspot/coldspot analysis of the nitrates by HUC10 zones. But there are over 600 HUC10 zones.
Thanks.
JL1
Hej Steve,
Thanks for the tip with the coordinate system: I converted my shapefiles from WGS 1984 to RT90 (swedish grid), which made the whole process work just fine:
- GA layer (Kriging/CoKriging)
- GA layer to Grid (raster, changing output cell size to 1; I need it to be one so that I can calculate the volumes at the various depths)
Thanks a million for the help
Cheers
Jürg
