Kriging Problem!
3800
04-30-2011 09:14 AM
jieding
I used the same rainfall data to do ordinary kriging in arcmap 9.3 and arcmap10.
In arcmap 9.3, the default parameters give a better predition map than the optimized parameters in arcmap10.
Does anyone know why this happens?
SteveLynch
How do you know that the predictions are better?
Thanks
Steve
Fevziakbas
Hi Steve,
Could you please a brief explanation about "optimize model "  in Arcgis 10 geostatistical analysis.
Is it sufficient to choose this option to provide best map to the user.
Fevziakbas
Hi Steve;
here is an  example.
Surface soil clay content semivariogram modelling and cross validation result.
Model :spherical
Model  -------------     Mean Pre. Err.-------- Root Mean. Sq.  -----    Root M sq Stand.
1 (optimized by program)     0.03453  --------     7.521  ------------ 1.036
2 (my semivariogram model)   0.0556 ---------  7.437  ------------  1.0741
Which one I should choose?
EricKrause
Hi Steve,
In kriging, the optimize button uses weighted least-squares.  The algorithm iterates through the range and fits the nugget and sill using weight least-squares for each iteration.  It then calculates the combination with the minimum root-mean-square.  Because the covariance matrix between the three parameters is not estimated, this process will not necessarily find the global root-mean-square minimum.  If you play with the parameters enough, you may find a better root-mean-square.
Looking at your cross-validation statistics, you can justify either model.  Your model has a better root-mean-square, but it has a worse mean prediction error and rmse-standardized.
