Kriging in Spatial Analyst / geostatistical Wizard
5495
03-03-2016 02:45 PM
RajPatnaik
Hi
We don't have data. To see how the results would be,  I created some random points with some values in float data type.
After which I ran geostatistical wizard. The data comply normal distribution with log transformation and also comply "stationary". I got the kriging prediction map from geostatistical wizard. The values are distributed within the range of 22.9862995 - 438.985992.
This resultant kringing prediction map when I try to export to raster, it does either (2) only exporting the covariance map from the geostatistical wizard or (2) only exponential values with no map - same way happening with the "Kriging tool" of spatial analyst.
Could anyone suggest a remedy?
Thank you
R
EricKrause
To export a geostatistical layer to a raster, use the GA Layer to Grid geoprocessing tool.  You must first create the geostatistical layer from the Geostatistical Wizard.  Once it is in the Table of Contents, use GA Layer to Grid to export it to a raster.
DanPatterson_Retired
