GA Layer The input Layer is not valid
4369
03-09-2013 11:48 AM
ronnysequera
I can't perform any conversion of any GA layer, because I get the input layer is not valid error(00966 the input layer is invalid, failed to execute GAlayerToGrid). I have searched the web but i can't find a solution, there is some info:
Input datasets
-Dataset
TypeTable
X fieldweather_stations.XUTM
Y fieldweather_stations.YUTM
Data field 1TablaMediasEtoFinal.ETo
Records55
-Dataset 2C:\Users\Ronny\Desktop\MDT-imagen\\elev_total
TypeRaster
-MethodCoKriging
TypeOrdinary
Output typePrediction
-Dataset #1
Trend typeNone
-Searching neighborhoodStandard
Neighbors to include5
Include at least2
Sector typeFour and 45 degree
Major semiaxis89,092.70592063243
Minor semiaxis89,092.70592063243
Angle0
-Dataset #2
Trend typeNone
Include at least2
Angle0
-Variogram[ Semivariogram; Semivariogram ]
Number of lags12
Lag size7,424.392160052703
Nugget[ 0; 0 ]
Measurement error %[ 100; 100 ]
Shift[ 0; 0; 0; 0 ]
-Model typeExponential
Range89,092.70592063243
AnisotropyNo
Partial sill[ 39.665489892777; 5.447216659401; 5.447216659401; 130,896.39275056786 ]
The model is working just fine, but i can't convert it to raster neither vector.
I'm running on Win7 64bit, 10.1 SP1 Desktop
SteveLynch
What happens if the data are in a feature class?. I.e it looks like your input is in a table.
If you do, for example, kriging (no cokriging), does it work?
Steve
ronnysequera
Steve
Thanks for the answer.
Its not working either way kriging or CoKriging but anyways I've been able to find the problem, since I have installed the 64bit BackgroundGP I try to do the operation throught python with the 32bit modules and works just fine and i get the raster to work with.
