ArcGIS 10.2 Model Builder soil sample points interpolation
5690
6
11-20-2014 07:40 AM
AndrewWindham
I have built a model in model builder that is supposed to take an unprojected shapefile join it to an excel table field  project the joined shapefile and then perform kriging using Geostatistical Analyst and then clip the raster output to a boundary. The model in the image below will project both the boundary and the raster however it will not clip the raster and when it is added to the map the boundary and the raster will not display in the same map as if the coordinate systems are different. I am not a programmer and an intermediate level GIS user I could really use some help!
Thanks
Tags (1)
ChrisDonohue__GISP
Sounds like a projection issue.  I don't know the exact issue going on, but here are some things to try to help isolate the issue:
1.  Check the projection and coordinate system of your Kriging output to see if it is what you expected.  If the Kriging result came out without a projection, you may have to define a projection for it.
2.  Check also the Data Frame projection and coodinate system to see what it is.
3.  Check the clip shapefile to see what it is.
Chris Donohue, GISP
ChrisDonohue__GISP
Another idea - I can't tell from your diagram, but is the Clip tool used the "Clip (Data Management)", not one of the other "Clip" tools?  There are several Clip tools, but the Data Management one is the specific one that does rasters and probably the one to use.
NeilAyres
A bit of advice, use it, don't use it.
Get your data sorted first before performing analysis.
What do you mean by "unprojected shapefile". Get it into a proper PCS first.
Get your excel into a proper table (fgdb, pgdb etc) format first. This will confirm that header are correct and that variables are not a different type than you expect.
Then perform your analysis.
ChadKopplin
The unprojected shapefile needs to have the original projection set, you cannot define it to something else, you would need to use the actual projection tools to change to projection or use the on the fly projection from the data frame.  The data will not display because the shapefile and the projection of the data frame do not truly match up.  Once each layer is defined to their native projections this should work.  I hope this helps.
ChrisDonohue__GISP
Neil and Chad have some good points to consider for anyone doing analysis.  What they mention are essentially best practices in organizing data for analysis.  By doing these best practices, one will avoid many headaches and help insure the results you get are valid.
To summarize:
1.  Start out by making sure all the inputs have projections and coordinate system before anything else.  If they already have a projection, but it is not he one desired, use a process to convert them to the one desired.  As Chad alludes to, avoid the pitfall of assigning a desired projection to something that already has a projection - instead, use one of the several methods to convert from the current projection to the desired one.
2.  Expanding on what Neil mentioned, it's usually best to take a feature class with joined data and combine it into one dataset before running analysis.  Take the joined dataset and create a new feature class from it.  This new feature class will permanently have the joined data in it, eliminating potential issues due to the Join.  Then check the result.  Note that it is common for issues in field names to crop up here, so checking it (and then editing your input Excel table to resolve them, if needed) is important.  For example, look out for field names in Excel that contain restricted characters, have spaces, are very long, etc.  Also, check that the data types are as expected.  For example, did a string field become a number type when it should of stayed string?  The bigger reason for doing this is that it identifies potential common issues before the model runs and blows up, or returns unexpected results.
Chris Donohue, GISP
AndrewWindham
Thanks guys let me try this and I will let you know the results.
Andrew
