Tracking vehicle locations using Cradlepoint routers
2453
01-19-2023 01:21 PM
ChuckS
I have Cradlepoint IBR1700 routers in vehicles and I would like to display their locations using the GeoEvent Server. In Cradlepoint NetCloud, I need to add a configuration for GPS Send to Server. I'm confident that I can get this working. I need to specify the GeoEvent Server URL, port number, and server other parameters.
https://customer.cradlepoint.com/s/article/How-to-Configure-GPS-Send-to-Server
I'm completely new to the GeoEvent Server and don't know where to start or even how to get an overview of using the GeoEvent Server. I think that would add an UDP Input to Receive Text from a UDP Socket. Can anyone point me in the right direction? Thanks.
JeffSilberberg
Chuck,
     This has been  open for awhile. Did you get your answers --  If not I would be happy to talk with you about a way to implement this. Currently we support a number of devices with NMEA or NEMA extended stream into our SaaS and then feed to geoEvent or Velocity using a PUSH to a Restful JSON defined Feed point, after that you can build your analytics around the feed.
