StreamServiceOutboundTransport issue
5127
11
04-23-2018 06:59 AM
AntonioCarrozzo1
I created a simple stream service with GeoEvent manager (10.6), but I have always the same issue
com.esri.ges.transport.streamService.StreamServiceOutboundTransportnull java.lang.NullPointerException at com.esri.ges.transport.streamService.StreamServiceOutboundTransport.receive(StreamServiceOutboundTransport.java:567) [83:com.esri.ges.framework.transport.stream-service-transport:10.6.0] at com.esri.ges.manager.stream.internal.OutboundTransportProxy.receive(OutboundTransportProxy.java:40) [127:com.esri.ges.manager.internal-streammanager:10.6.0] at com.esri.ges.manager.stream.internal.OutboundStreamImpl.receive(OutboundStreamImpl.java:202) [127:com.esri.ges.manager.internal-streammanager:10.6.0] at com.esri.ges.adapter.OutboundAdapterBase.receive(OutboundAdapterBase.java:44) [29:com.esri.ges.framework.adapter.adapter-api:10.6.0] at com.esri.ges.adapter.json.FeatureJsonOutboundAdapter.flushQueue(FeatureJsonOutboundAdapter.java:118) [31:com.esri.ges.framework.adapter.feature-json-adapter:10.6.0] at com.esri.ges.adapter.json.FeatureJsonOutboundAdapter.run(FeatureJsonOutboundAdapter.java:91) [31:com.esri.ges.framework.adapter.feature-json-adapter:10.6.0] at java.lang.Thread.run(Thread.java:748) [?:?]Apr 23, 2018, 3:22:34 PMERROR
I able to subscribe the stream service, and the counter is updated every time a new file has been uploaded to the folder
Could you please help me.
Irina_Rakhimova
Hi Roland,
As far as I know GeoEvent environment and stream services are stable.
The browser cert was imported to make sure that I get all certs (root,intermediate,final) imported. I am not sure if it was necessary, but it did help me with StreamServiceOutboundTransport error.  Additionally, if you have IE Enhanced Security setting enabled, maybe you could try to turn it off as a test.
Thank you,
Irina.
Rolandvan_Zoest
This problem still exists in version 10.6.1
Could someone from ESRI staff confirm and explain the solution suggested by Irina Rakhimova ?
Thanks, Roland
