Recommendation - NMEA Message Provider for Windows
3962
06-05-2014 05:50 AM
SebastianLuhmer
With the NMEA Connector for ArcGIS GeoEvent processor it is possible to sent GPS-Positions via TCP, UDP etc. to the GEP. Within the NMEA Adapter tutorial the commercial application GPS 2 IP for iOS-Devices is mentioned.
I am looking for a free software on a Windows OS to do this. Does anybody have a hint wich software I could use for this purpose? After doing some recherche, I just found GPSGate that is related with costs.
Regards,
Sebastian
JasonCollins1
I've been testing GeoEvent with our Windows laptops and using two pieces of software to make it work. However, I'm interested in GPS Gate and will check it out.
X-port to create virtual serial ports, and VSEP to act as the http client that sends back the data. However, the less moving parts the better in my opinion.
X-port: http://www.curioustech.net/xport.html
VSPE: http://www.eterlogic.com/Products.VSPE.html
SebastianLuhmer
Hi Jason,
thanks for your quick reply. I am struggling with my 64-bit machine. XPORT is just available for 32-bit- machines and VSPE needs a costly license to be deployed in a 64-bit environment. The simulation of a COM-Port with GPS-Gate is also available in the free version but you can just send the data to COM-Output (and not directly to tcp/udp). So I "just" need an alternative for VSPE to send the GPS-Position data from COM-Port to TCP/UDP within a 64-bit environment. Do you have an idea?
All the best!
Sebastian
JasonCollins1
Sebastian,
I'm glad you brought up that point. So far in testing, I've only used 32-bit machines. Most of the boxes we have here are 32 and I'm not sure when the migration to 64 will be. So, I have no idea. I've been considering getting someone to custom code this functionality so that 1, we won't have multiple pieces of software "daisy-chaining" that might break somewhere, and 2, because we will be having approximately 250-300 machines running this when implemented. We've also had some issues where GeoEvent will create a new feature if the network connection is dropped and reconnected. Not sure if that is part of the problem with these pieces of software or something else, but I try to minimize any issues that I can from the start.
We're also testing a Sierra Wireless unit, but it sends the sentences back automatically without any PC interaction. Which is nice.
If I do go the custom route or have any further luck with things, I will reply back in this thread. It appears that this will be a problem for many users until someone with coding skills decides to make some money for this market.
Good Luck!
Jason
