Multiple Geofences - geotagging
1080
09-29-2017 07:58 AM
AllenScully
I have what I think is a fairly straightforward scenario in GeoEvent processor - Points as input, going into a filter that uses two geofences, if a point is in GeoFence 1 or in GeoFence 2...
The output feature class that gets written to has 2 attribute fields to accept the Name from GeoFence1 and GeoFence2 - fairly simple so far.
So I have a GeoTagger processor to grab the Name field and map it to the appropriate attribute in the output feature class.  All works well for a single Geofence, but what I am wondering is if you can have the GeoTagger create field names for both GeoFences, so that the geotagger definition has GeoFence1 AND GeoFence2 Category/Name in the output - something like this:
Is it possible to get this done with a single GeoTagger?
Thanks -
Allen
