GeoEvent Fails to Update AGOL Feature
4219
10
01-26-2017 11:38 AM
thomasbales
I just finished installing ArcGIS Server Standard 10.5 and its accompanying GeoEvent Server and have not been able to update one of my  AGOL hosted feature layers. Prior to the install I was able to do this. The service is a basic feature service poll in -> field mapper -> feature service update.
Checking my log file i get the following message
Error while writing to feature service fleet_cloud_test. Error: {"error":{"code":400,"message":"","details":["'rollbackonfailure' parameter is invalid"]}}.
How do I fix this?
thomasbales
Well, I searched support a found out a patch for GEP 10.5 was released. On my first attempt installed the patch and I could not restart my GeoEvent service. So, I uninstalled then reinstalled (GEP) and then stopped both the ArcGIS Server and GEP while I re-installed the patch. Fired them both back up and  wolla, worked perfect. No problems updating my service.
Here is the link
ArcGIS GeoEvent Server 10.5 Patch 1
KevinHatch
We are having the same issue following the 10.5 update.  Did you have any resolution on this?
thomasbales
No, but strangely I am able to add features but not update. I had to write some python code to overwrite the hosted feature service from a local gdb and map document. It works for now, but I can't update my hosted service faster than 30 seconds. Not a long term solution. I will reach out again to esri support next week.
Javier_RodolfoPintos_Ettlin
Hello! good morning!
I have a problem trying to "Update a feature" from Geoevent to ArcGIS Online. When I try to do the same in Portal, it works well.
The Feature has the correct permissions, also when I simulate an updateFeature via POST passing the code in JSON, it works fine.
The only strange thing I see is that in the Geoevent Log, the same parameter is passed twice but with different values:
com.esri.ges.transport.featureService.
FeatureServiceOutboundTransport
Posting to URL: https://services.arcgis.com/KXXXXXXXXXXXXXT/arcgis/rest/services/RendimientoInstantaneo/FeatureServe... with parameters: features=[{"geometry":{"x":-63.23714,"y":-31.42259,"spatialReference":{"wkid":4326}},"attributes":{"maquina":"Claas Lexion 770 1","velocidad":6.3,"rendimiento":9.553,"humedad":16.9,"fecha":1492094652672,"OBJECTID":2}},{"geometry":{"x":-63.23628,"y":-31.42899,"spatialReference":{"wkid":4326}},"attributes":{"maquina":"Claas Lexion 770 2","velocidad":5.6,"rendimiento":9.965,"humedad":18.6,"fecha":1492094653704,"OBJECTID":3}},{"geometry":{"x":-63.23528,"y":-31.42123,"spatialReference":{"wkid":4326}},"attributes":{"maquina":"Claas Lexion 770 3","velocidad":6.5,"rendimiento":10.994,"humedad":17.2,"fecha":1492094651674,"OBJECTID":1}}]&rollbackOnFailure=false&f=json&token=NaIX_JMfrUdhTSrx3wr4Hxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxwy_GCBDb-xihEiL2-WfWkk7JvZ8NuYy1214NoJBA11wswiHiHhFA4Dmv8LOVfVdpDxZko9Uk8IVvEYAF5C0t8DgBKisfoFLL_8oAW9BculznYKOAaOqKOWfHlJCiG6pFyBWvLKyFJS3ZMT65XL-0J9C25RjZpc6kwTlSIeCKLFZaTP-UVXd7fzrpX1iEYjg67NN31b1Xh2Y-9IOhiJb-UIwQ..&rollbackOnFailure=true.13/04/2017 11:44DEBUG
Somebody happened to something similar, do they have any recommendations?
Thank you very much.
Best regards.
P.S: I want to clarify that the output correctly adds the geoevent the first time but does not update the feature the second time.
thomasbales
Were you able to resolve this?
No.
I am searching any alternative because "Update a Feature" in AGOL not found.
thomasbales
For the time being I am using python code to update my hosted feature service. It is not a solid solution but I have been getting by using python. Here is the link. If you solve this please let me known. This issue has been a major thorn in my side. I spent one month on trying to solve this with no luck except I can add features to the existing hosted feature but I can't just update them.
Updating ArcGIS.com Hosted Feature Services with Python | ArcGIS Blog
Yes, a have the same problem.
I will intent with Python.
Thank you very much Thomas.
I'll be in touch.
Regars.
thomasbales
FYI, the process is to run the back end scripts that modify the data in
local geodatabase and once the models and scripts are complete you push
the mxd up to the cloud and overwrite the hosted service. I find that I
can get this option to work in every 30 second cycles. For my purposes 30
seconds is good enough but that is the limitation with the script. On the
other hand, it is a lot easier to get custom data into the feature using
python rather than the GeoEvent SDK.
Cheers,
Tom
Thomas Bales
GIS System Architect
Loram Maintenance of Way, Inc.
3900 Arrowhead Drive
Hamel, Minnesota 55340
Cell: 612-875-3154
thomasbales
Here is the link
