Failed to create a GeoEvent from incoming JSON feature. Unexpected error occurred. java.lang.ArrayIndexOutOfBoundsException' On ArcGIS Server 10.4.1
3458
06-07-2016 01:11 PM
AndrewCallison
Upgraded to ArcGIS Server 10.4.1 with geoevents extension. On 10.3.1, I wasn't getting an error after the upgrade getting a 'Failed to create a GeoEvent from incoming JSON feature. Unexpected error occurred. java.lang.ArrayIndexOutOfBoundsException' on one of the Inputs Connectors.
Error Log-
I have the Feature service on on the same server. Data is coming from a ArcSDE Layer from Oracle 11g.
Any Suggestions or Ideas why I would get this?
Drew
AlexanderBrown5
Drew,
Have you also upgraded your GeoEvent extension to 10.4.1 as well?  Are your data stores validated properly after your upgrade?
~Alex
