Connection to PI integrator - no data transfer
1256
08-08-2016 08:36 PM
BenScott1
Hello - we are trying to connect in geoevent to PI integrator, and are able to create a connection which appears to be ok, but for some reason the geoevent connection cannot receive data.  It shows up in the monitor as receiving no data.
We can use the url and parameters to retrieve json data so the data appears to be available from PI integrator and the url is correctly parameterised. The PI integrator server is available and trusted to the server running geoevent  We have tried using https and http and with and without our url proxy, all with the same result.  Some screenshots below.
Cheers,
Ben
