Windows Mobile Editable layers
2826
03-02-2012 08:44 AM
LeeKaufman
I am working to create a Windows Mobile application with a editable layer that is a point feature class in a SQL Server 2008 R2 database using the geography spatial data type.  I have created a .mxd using ArcView and added the layer, then saved the mxd and published it to our Arc 10 Server.  However, when I bring the layer into the Mobile Project center the 'Editable' check box is grayed out.  Does anyone have any advice on how to enable editing?
TimHopper
Feature Classes that you intend to edit in ArcGIS Mobile need to have Global ID's.
LeeKaufman
Thanks Tim,
I am familiar with how to do this in ArcCatalog for a file geodatabases, however for the feature classes in my SQL Server database I do not see the Add Glogal ID's option that I have for a file geodatabases.  Can I use ArcView or a command on the SDE server or does this feature require ArcEdit/Info?
Lee
TimHopper
Ah, my apologies.
In order to make a layer editable it must reside in either a single-user or multi-user geodatabase.  If it resides outside of a geodatabase, you will not be able to edit the layer in ArcGIS for Windows Mobile.  From the looks of it, you've just got a table outside of a geodatabase which has the geography spatial data type, correct?
LeeKaufman
That is correct, the layer was added to the mxd via a Spatial Database connection.  Is there a way to keep the table in the existing SQL Server database and still expose it as editable in Windows Mobile?
Lee
TimHopper
Unfortunately there isn't.  You would have to put it into a geodatabase which resides in SQL Server (at that point it would just become a feature class, wouldn't really be connected to the SQL Server spatial data type anymore).  Without the file being in a geodatabase, it cannot utilize the functionality required for editing.
