VRS with Windows Mobile
1817
04-10-2014 04:20 AM
ErikBlake
I currently use ArcPad which allows me to connect to ODOT VRS system. Is it possible to connect to the VRS using windows mobile?
Erik
PaulLohr
Hello,
You probably want to check into Trimble Positions. Make sure it supports your device. You might get a Trimble salesman to give you a demo with a device having ArcGIS Mobile and Trimble Positions. If you have an IP address, port number, and credentials for a certain VRS, you might want to have those ready for the salesman.
Some of the more advanced GPS receivers can output a VRS corrected NMEA message to ArcGIS Mobile. Of course the receiver has to be able to take in a VRS correction and work with those corrections. It is a bit of work to get this up and running.
If you are thinking of getting centimeter accuracy vertical positions, check if ArcGIS Mobile can correct based on a geoid model.
http://trl.trimble.com/docushare/dsweb/Get/Document-621961/022501-296G_Trimble%20Positions_DS_1013_H...
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
