Unable to sync new features using synchronization task
5221
04-26-2015 09:05 AM
PramodHarithsa1
Hi All,
I am unable to sync the newly collected features back to SDE although i am able to edit and update attributes for existing features.
Even after using synchronization task the new features, the edits remain in manage edits without throwing any errors,
Background:
Using MPC to configure the application
ArcGIS Server 10.2.2
ArcGIS for Windows Mobile 10.2
I have enabled archiving and Global Id's on the Dataset in use
I have also enabled allow collection of new features option in MPC.
Unable to figure out what is being missed.
PramodHarithsa1
Juan,
Albeit bit late, we got that working after enabling versioning on the dataset.
Regards,
Pramod
JuanLuera
Hola,
This would be a great issue for us to work with you on, from within Support Services. We could acquire from information from you (data, prj, etc.) then would be able to troubleshoot the issue with you, to determine why you are not able to sync your updates. Gracias!
Please remember to be current on your maintenance, then call or submit a webform
Contact Tech Support
http://support.esri.com/phoneSupport#us
http://support.esri.com/en/webform
Juan
PramodHarithsa1
Juan,
Regards,
Pramod
JuanLuera
Pramod,
Gracias for the update! Great to Hear it all worked for you.
Juan
