syncronizing mobilecache
714
07-31-2012 07:45 AM
LisaT
Hi, I am trying to synchronize my mobile mapcache.  I have used a lot of different code snippits and am coming across a "remote server returned an error:(401) unauthorized" at every turn.  I have a post in the general ArcGIS Server 10 forums having to do with permissions on the mapservice, but am also wanting to post here to fish for ideas.  Mainly: is there any way to sync a mobilecache (via code) WITHOUT using a mapservice??  I can extract a mobilecache using the mobile GP tools, and this only uses an MXD.  Is there a way to, with code, use just the mxd?  If so, does anyone have a code snippit?
If there is no alternative way to synchronize the cache, maybe someone has an idea of what is going on?  I have the arcgisoutput virtual directory set up with full permissions for the arcgiswebservices user, and have anonymous access enabled to use the arcgiswebservices user.  There are no token credentials set. the arcgiswebservices user has full permissions on the cache folder as well as the output folder.  Security has not been enabled on the mapservice.  I cannot view the wsdl (same 401 error).
