Snapping in ArcGIS Windows Mobile Application
1759
08-04-2011 11:53 AM
SethHays
We are having trouble getting snapping to work properly in the ArcGIS Windows Mobile Application. When editing with snapping enabled, the orange sketch point snaps to the vertex of another layer as it should. The problem is that when the user clicks to enter the point at that snapped location the sketch point is saved at the mouseclick location instead of the expected snap location. The resulting point is always very close but never truly snapped to the intended vertex.
This is occurring with the out-of-the-box wpf app without any customized extensions.
Has anyone else encountered this behavior?
jacobtustison
I am having a problem with snapping a point feature to another point feature any ideas???
SethHays
The latest ArcGIS Mobile Build (Build 2525) fixed the snapping problem for us. You might try installing it if you are running an older version.
NickDeMerchant
Has anyone been able to setup snapping from the out of the box Mobile 10?  I don't really see anything there and there is nothing documented on this.
Thanks for any info,
Nick
