SaveGPS Values Lat and Long (WIN)
1240
10-19-2010 09:29 AM
AkhilParujanwala
Hi, I am working on trying get Lat and Long values and then store them into the new feature being collected. There is a Windows Mobile sample which works perfectly fine (after some modifications). However when I tried to re-write the code to make it work for Windows Tablet versions, it doesn't work at all and causes the program crash.
below is the code I am using for testing purposes.
public class GPSValues_Win : ProjectExtension
        private CollectFeaturesTask m_collectFeaturesTask;
        private GpsConnection gps;
        private GpsAveragingGeometryCollectionMethod m_GPSAveraging;
        protected override void Initialize()
            gps = MobileApplication.Current.GpsConnectionManager.Connection;
            m_collectFeaturesTask = MobileApplication.Current.Project.Tasks.GetFirstExtensionOfType(typeof(CollectFeaturesTask)) as CollectFeaturesTask;
            m_GPSAveraging = new GpsAveragingGeometryCollectionMethod();
            //m_GPSAveraging.Completed += new EventHandler<CompletedEventArgs>(Geometry_Completed);
            m_GPSAveraging.Completed += new EventHandler<CompletedEventArgs>(m_GPSAveraging_Completed);
            //ESRI.ArcGIS.Mobile.Client.Windows.MessageBox.ShowDialog("this happens whe you device to pick a collection method");
        void m_GPSAveraging_Completed(object sender, CompletedEventArgs e)
            ESRI.ArcGIS.Mobile.Client.Windows.MessageBox.ShowDialog("This happens when GPS is complete");
The code sample for Windows Mobile that ESRI provides is located here:
http://www.arcgis.com/home/item.html?id=c11fa66674a9422c881061fec9197d73
Thanks in advance for your help.
Akhil P.
