Non-editable Layer
3266
08-16-2010 02:23 PM
AlexProtyagov
For some reason all feature layers of my mobile cache are read-only. Would you know what
needs to be done in order to be able to add values (points, polylines, etc) to a feature layer ?  My suspicion is that I need to setup something in my map document, mxd file. Or perhaps when I make the cache I need to do some extra step?
In the following code I get exception that the feature layer is not editable:
            // Selects a specific cache layer
            FeatureLayer featureLayer = _cacheData.Layers[0] as FeatureLayer;
            // Gets the feature layer data table schema
            FeatureDataTable featureDataTable = featureLayer.GetDataTable( );
            // Creates a new row
            FeatureDataRow featureDataRow = featureDataTable.NewRow( );
Last line raises exception "The target feature layer does not allow creation of new features."
MaximilianGlas
To check if it is possible to edit data you can use
if (featureLayer.AllowNew || featureLayer.AllowModify)
The only condition for editing data is an existing GLOBAL_ID field in the feature class. You can add it in ArcCatalog.
AlexProtyagov
Thank you. That appears to be the only way, the GLOBALID on the feature class. When I did that it was editable on mobile just fine.
Just for curiosity, - is it possible to make an editable layers for mobile devices from shape files? Somehow when I make a layer from a shape file it read-only on mobile. However, it is ok since I can edit SDE feature classes derived from oracle db.
Obviously a feature class built from a database view does not support globalid simply because views are not editable. Is there a trick to make a feature class derived a view editable on mobile device. The  idea is that the layer only gets downloaded to the device, it never gets back to database via Sync method. Again, I am just curious on that part
EzequiasRodrigues_da_Rocha
I think the Operation Allowed in ArcGIS Server Mobile Service must be ON (to insert/delete/update). Are you agree with me?
Regards
Ezequias
