Mobile 10.2.1 compatable with ArcGIS Server 10.4
8553
6
02-22-2016 10:53 AM
DavidColey
MVP Frequent Contributor
Hi - does anyone know if Mobile 10.2.1 compatable with ArcGIS Server 10.4?
Thanks
David
DeniseKing
Esri is now providing customers with v10.4 compatible Mobile GP Tools who are using ArcGIS for Windows Mobile v10.2.1 and upgraded to ArcGIS Desktop/Server 10.4.x. Please review Knowledge Article What is the ArcGIS for Windows Mobile GP Tools Utility 10.2.1 for ArcGIS 10.4.x? which describes that the ArcGIS for Windows Mobile GP Tools Utility 10.2.1 can be obtained by customer's submitting a Support Case, http://my.esri.com.
Thank you,
Denise
DavidColey
Hello again all - does anyone know if ArcGIS 10.2.1 for Windows Mobile is compatabile with the ArcGIS 10.4 release?  I am speaking specifically about the Additional Products Download section of MyEsri. For ArcGIS for Desktop 10.4.  The  ArcGIS 10.2.1 for Windows Mobile additional product lists that it is compatable with ArcGIS 10.3.  Is this true for 10.4?
ArcGIS 10.2.1 for Windows Mobile (compatible with ArcGIS 10.3)
Thanks-
David
DavidColey
Hi again -  The answer here appears to be no.  After upgrading to Desktop 10..4, the goeprocessing tools and arcpy module as downloaded from the are not installed after running the setup.exe for the  ArcGIS 10.2.1 for Windows Mobile.
I of course have migrated to Collector but unfortunately have a couple of third party mobile SDK applications that require the use of  a mobile cache.  I'll keep a desktop at 10.3.1 in order to run the gp tools but it will certainly help to have the 10.4 compatible release--
Does anyone know if ESRI is going to release a 10.4 compatible install?  Esri?
DavidColey
Hello - Esri support indicates that no additional update to the installation package will be available and as such the Mobile GP Tools will not be available for Desktop 10.4x.  The Mobile GP Tools will continue to install on 10.3x.
It is unfortunate that the Mobile install remains as a download under the additional products section for 10.4 as its confusing.
roemhildtg
It really appears that these tools should work with 10.3, 10.4, etc. The documentation clearly describes licensing being available for these tools.
Mobile toolbox licensing—Help | ArcGIS for Desktop
DavidColey
Yes I agree but they don't seem to register with python 2.7.10
DeniseKing
Thank you,
Denise
