Missing DisplayExpression method in MapLayer Class in SDK 3.1 for Windows Mobile
2187
05-07-2014 01:49 AM
AndreaV
we are migrating an application from ArcGIS Windows Mobile 10.0 to ArcGIS Runtime 3.1 for Windows Mobile.
We use a method 'DisplayExpression' to limit feature class visibility on a map, but it's missing on new SDK MapLayer Class.
Is there a way to obtain same functionality at runtime with new versione of SDK ?
Regards,
Andrea
AkhilParujanwala
I personally still use the 10.0 SDK.
I had a look at the latest SDK because I also use the DisplayExpression object.
In this link, click on Index, then Find (CTRL + F), type DisplayExpression, you will see that the property is within the MobileCacheMapLayerDefinition object.
http://resources.arcgis.com/en/help/windows-mobile-sdk/3.1/apiref/index.html
If you don't mind, once you do get it to work, please share the code for others.
I hope this helps.
AndreaV
Very helpful, we will try to implement via that object.
many thanks
I hope this helps.
