Missing ArcGIS registry key
4058
02-24-2014 03:52 AM
MohammadAbuTahoun
trying to create an arcgis windows mobile 6 application using the 10.2 windows mobile SDK.
currently I am using the sample that comes with the SDK "WM-Walkthrough",I get the error "Missing ArcGIS registry key" when the code reaches mobileCache1.Open();
I have installed the "AGMRuntime.CAB" on booth a simulator and a windows device and I still get the same message.
any help would be appreciated.
RobertMEIER
have you found an answer to this issue yet? I'm having the same problem.
Noah-Sager
It sounds like you may be facing a known issue with the Windows Mobile SDK 10.2:
NIM097317: A "Missing ArcGIS Registry Key" error occurs due to a registry key mismatch.
The current workaround is to create a new registry key, Mobile10.2.0, at the same place as the Mobile10.2. Here is an example of where that should be found:
(old) HKEY_LOCAL_MACHINE\Software\ESRI\Mobile10.2\InstallDir
(new) HKEY_LOCAL_MACHINE\Software\ESRI\Mobile10.2.0\InstallDir
Note that you must change the registry key on the Windows Mobile device as well.
Hope this helps!
-Noah
