Is it possible to debug an ArcGIS Mobile Task in Visual Studio
8919
11
02-01-2011 03:04 AM
NilsRydh
I have created an ArcGIS Mobile application for Windows Mobile 6 using only the Esri.ArcGIS.Mobile assembly. Debugging works fine in Visual Studio.
When I try to develop my own Task using the Esri.ArcGIS.Mobile.Client assembly, the project output is a dll and should be added to a project in the project center or in the .ame file.
Now, my question is: Is it possible to use debugging in Visual Studio when developing a task for Windows Mobile 6?
NilsRydh
I've tried debugging a custom task in Windows 7, no problems. You need to do three things:
1. Create a project with the task added correctly.
2. In project properties, set the Build output to [ArcGIS Install path]\Mobile10.0\bin\
3. In debug properties, select "Start external program" as start action and set the path to [ArcGIS Install path]\Mobile10.0\bin\ArcGISMobile.exe
AkhilParujanwala
Thank you so much for the detailed instructions. This works for even Extensions, which is the majority of the work I do. It's been about 7 months of programming without being able to Debug!
NOW I CAN!
I really owe you one for this!
Akhil P.
