Install Application in Windows 7 x64
3199
02-21-2013 04:14 AM
WesleyAntal2
I need install a application in client machine, but when I create a setup install and execute the application a error is show:
"Fail in initialize (ISupportInitialize.EndInit). [...] 'ESRI.ARCGis.Mobile.CoreApi.NativeMethods' in exception [...]".
I try register DLL in GAC, but a error occurred ("DllRegisterServer not localizabled").
How I do for install this application in client?
PS: Application Solution is: .NET+WPF
     Client Machine: Windows 7 x64
DeniseKing
Wesley,
My apologies, here is system requirements page for ArcGIS for Windows Mobile 3.0 but I 'm not sure that's what you are actually using since original post mentions 'Applications Solution is .NET + WPF' (available only w/ArcGIS for Windows Mobile 10.1.1 release). Provide screenshot of installed Programs from Control Panel - specifically ArcGIS software.
See Forums thread which mentions uninstalling & removing all dependencies of older version of ArcGIS that perhaps wasn't completely removed during uninstall procedure; then install ArcGIS Desktop 10.1; next install ArcGIS for Windows Mobile 10.1.1 (download available on Customer Care Portal); followed by installing ArcGIS Runtime SDK for Windows Mobile 10.1.1. See system requirements page for ArcGIS for Windows Mobile 10.1.1 for additional details.
Denise
DeniseKing
Wesley,
Your post doesn't say which version of ArcGIS for Windows Mobile you've installed on Windows 7 64bit OS; please refer to system requirements for the version of ArcGIS for Windows Mobile installed as there is likely additional software requirements.
ArcGIS for Windows Mobile 10.1.1 release on Windows 7 32-bit/64-bit also requires Microsoft .NET Framework 3.5 SP1 installed
Please see past Help releases for those system requirements.
Denise
WesleyAntal2
Hi Denise,
In "client machine" I don't installed ArcGIS Mobile, I installed in my machine to development this application.
The version installed in my computer is Mobile 10.1 (package arcGIS 10.1), that installed is Mobile 3.0. I don't understand this version controller, but it's.
PS: The "client machine" have installed .NET Framework 3.5 SP1.
thanks.
DeniseKing
Wesley,
Denise
WesleyAntal2
Denise,
I uninstalled the version 10.1 of Mobile and Installed the release 10.1.1.The problem is resolve.
Thanks for help.
