how to  set the queryfilter.where with date  type
793
11-02-2010 08:42 PM
yanli
i  want to search feature by date?code like this
 string qstr = "??????????='" + System.DateTime.Today.ToShortDateString()+ "'";
ESRI.ArcGIS.Mobile.QueryFilter qf = new ESRI.ArcGIS.Mobile.QueryFilter(qstr, true);
   FeatureDataTable fdtabel = featureLayer.GetDataTable(qf, null);
    dataGridView1.DataSource = fdtabel;
error:The 'where clause' is invalid.
whre's wrong  ?anyone can help me?
AkhilParujanwala
Have a look at my thread, there's a solution posted:
http://forums.arcgis.com/threads/13983-A-Simple-Query-of-a-FeatureClass-%28Help-Please%29
The first thing I see is you where clause may not be correct.
1) have messagebox pop up and show you your querystring (qstr).
2) The result from your query string should be
修�?��?��?� = 'Oct. 10, 2010'
This is just an example.
But if you need to see those apostrophe around the value (single quotes).
If you get a result like this:
修�?��?��?� = Oct. 10, 2010
or
修�?��?��?� = "Oct. 10, 2010"
You will get an error.
My code that I used is to solve this is:
string whereClause = "UserID = " + "'" + user + "'";
As you can see wrapped around user there is, quotation marks (double quotes), apostrophe (single quotes), quotation marks (double quotes) then a plus sign and then the variable (in your case Date) and then the rest is the same.
Let me know if this helps.
yanli
HI,AkhilP
i get the result from my query string
like this  修�?��?��?� = 'Oct. 10, 2010'
it is still error
then i  find in  the 9.2 help
i write query string  like this "  修�?��?��?� =date  '2010-11-03'  "
it's correct!!!
thank you all the same
