How can you edit JSON with an on premise server
1708
10-02-2011 01:42 PM
ErinAtkinson
Is there a way to edit the JSON code after it has been published as a map when working with an on premise server?  Going through ArcGIS.com to get the JSON code is royal pain, seems like there ought to be a better way.
Esri - do you have any other documentation related to publishing a map with an on premise server besides this one? http://help.arcgis.com/en/arcgismobile/10.0/apis/iphone/AppGuide/Maps.pdf
Thanks!
PaulLohr
On your arcgis server installation, go to the place where your arcgis mobile content is published. By default, I think this is \inetpub\wwwroot\ArcGIS\Mobile\ItemsRoot\<map_id>.
In the folder named <map_id> you should have a text file with the JSON content.
Does this answer your question?
Paul Lohr
Lohr Geospatial Services, Inc.
ErinAtkinson
Paul - thanks for your help!  That's exactly what I needed to know.
