Duplicate Feature Issue After Sync is Performed
849
11-03-2011 03:16 AM
StevenBlitzstein
I am having a problem where any "original features" which I edit or attribute in my Mobile project, become stacked or duplicated on top of one another once I perform the Synchronize Mobile Cache tool in my ArcMap project.
I am generating these "original features" from the same Feature class in my MXD project, and perform the Create Mobile Map, in order to cache these features for my mobile project.
It appears as though the features which I edit or attribute in my mobile project, end up becoming stacked or duplicated on top of one another in the same location once I perform the Synchronize Mobile Cache.
When I view my changes in my Mobile Project Center, everything is correct and as it should be. It isn't until I perform the Synchronization to my MXD that this problem is occurring.
Is there something I am doing wrong? What is the reasoning behind this and how can I prevent it from happening?
(Note: If a feature from the same Feature class is created from within my Mobile project, and is then Synchronized back into my MXD, along with my "original features", it will remain in the exact location where I created it, fully attributed.)
StevenBlitzstein
The only solution which I have found, is to store your data in a File GeoDataBase, and not in a Personal.
Hope this helps other people going through the same thing.
