Cannot connect to Server. Problem
4253
02-24-2014 07:47 AM
Ryan_Galbraith
I installed ArcGIS for Mobile on my older Juno and I keep getting the same error then crash.
It just says - "cannot connect to server".  I press OK then crash.  Any help?
by Anonymous User
Not applicable
Original User: mmf68
I'm getting the same error and crash on my Juno SB running ArcGIS for Windows Mobile 10.2
Any help on this would be appreciated!
AkhilParujanwala
I am still using 10.0 but I'm sure I had this problem several years ago.
When you use ArcGIS Project Center make sure you are using the fully qualified domain name (FQDN) of the server.
Before adding the service to your project, you need to type in the name of the server of where your services are located.
In some cases you need the FQDN depending on how the server is setup.
An example without FQDN: MyGISServer/Arcgis/mobile
With FQDN: MyGISServer.division.local/Arcgis/mobile
I hope this helps.
