Can't save Empty values for Domain Attributes
1019
08-25-2010 01:44 PM
HyrumErnstrom
I'm working on a mobile project in 9.3.1 winforms. I have a layer with several CodeValue Domain. Everytime I go to save if I don't input a value into the domain attributes it will fail. If I do the same edit in ArcMap I can leave the field empty and it will save. Is this a feature of the Mobile SDK?
AkhilParujanwala
When I used 9.3.1 I believe I had a similar issue. So when you create your domains, you need to set a default code value for the particular field in which the domain is going to be used in.
In other words when you created a coded domain you must make sure each field in which a domain is used in has a default value ( a code value).
Hopefully this solves your problem.
