Calculate Checksum ?
3589
05-05-2012 07:55 AM
OlivierOlivier
I would like to modify some fields mobilecache.db from a legacy application that could then be connected to Arcgis Mobile. My problem is that there is a checksum inside each record of sqlite database. Is it a standard checksum that I could recalculate ? Which formula ?
Thanks a lot,
Olivier
MaximilianGlas
The checksum is not calculated by client, it is calculated by the server for each change in the schema. It could not be changed by client.
