Annotation text is not Properly displayed in the ArcGIS mobile 10
2225
03-21-2011 10:41 PM
RajhpandianNatarajan
Annotation text is not getting displayed properly in the ArcGISmobile. I could see the  annotation text are inverted, in different angle , upside down. Is there any solution to display the annotation text properly in the Mobile.
Is there any settings need to be done while creating the annotation feature class or in the mxd. Is there any other work around?
Regards,
Rajhpandian N
DanGriffin
I'm also having a problem with annotation in Mobile.  Any ideas?
DeniseKing
Which ArcGIS Mobile 10 Update is installed? We have released ArcGIS Mobile 10.0 Update 4 [Build 2550] which includes some annotation fixes. Have you submitted your annotation items to Esri Support ? It will help if you can be more specific regarding annotation display items and include sample data, screenshots, and reproducible workflow for Mobile Team to review and test.
Regards,
Denise
MiguelGarriga1
Hi Denise,
We were also having problems with Annotation in ArcGIS Mobile.  This annotation looks and behaves perfectly in ArcGIS Desktop, but there is a lot of overposting on Mobile.  The fonts and colors look fine - the problems are the overposting and placement.
We just installed Build 2550 but it still happens - see attached image showing jumbled annotation.  The quality updates listed for 5220 include this reference to anno in the Mobile Project Center - is there anything we can do from Mobile Project Center to improve the behavior of annotation ?  There are no quality updates listed for Annotation in ArcGIS Mobile itself:
    NIM067039 �?? When displaying your map content using the Mobile Project Center application, we have improved upon
     how we display Annotation from a geodatabase annotation feature class.
We are using the Desktop workflow for ArcGIS Mobile (not the ArcGIS Server workflow) -- creating the map cache and copying to USB flash drive for mobile device.
Thanks for any info on how to improve annotation for ArcGIS Mobile - let me know if you need any more information.
- Miguel
ErickJohnson
Has there been any resolution on this issue???
Erick Johnson
