Accessing ArcgisOnline feature service
3635
11-28-2013 12:51 PM
RodLockie
I am looking for solution to accessing arcgis online feature service in arcgis for windows mobile 10.2.
I put the service address in the URL when I click on add feature service. Put username and password in both token and network credentials.
When i click ok I get Token required. Is this a network issue on my end or am i missing some settings in arcgisonline.
Rod
JohnFannon
We are experiencing the same issue - we have followed the sample here:
'>http://resources.arcgis.com/en/help/windows-mobile-sdk/concepts/index.html#//01sp0000007q000000
We create the token, but then it errors on Initialize() and the exception says 'Token Required'.
I'm convinced this should work, but it's not.
We are in the process of raising it with Esri UK and will report back anything useful.
JohnFannon
We now have a call raised with Esri UK on this as it appears that something has changed recently in ArcGIS Online that has caused sync with AGOL feature services to stop working.
A few weeks back we were able to publish a feature service to AGOL and then add it to Mobile Project Center and use it within ArcGIS Mobile for Windows 10.2. However, if I try the same thing today I can publish the feature service, but when adding it to MPC it says 'Token Required'. If we try to access an existing AGOL feature service via ArcGIS Mobile 10.2 that was working fine, we get continually prompted for credentials.
I'll feed back anything I get from Esri UK.
JohnFannon
As of yesterday (16/12/2013) this is now working and we are not getting prompted continually or receiving the 'Token Required' error. I'm still waiting from Esri on what caused the issue and for some assurance that it won't happen again.
