Site Workflows
2851
05-22-2014 10:20 AM
drakefinley
My question is there a way to set up the workflow to automatically login someone into ArcGIS Online? In others words when I bring up my sharepoint page with a web part attached via ArcGIS Online, the map is already showing and I don't have to continue to log into ArcGIS Online every time.
Thanks in advance.
KatherineDalton
Hello Drake,If you are using Esri Maps for SharePoint Beta 2, we currently have a mechanism by which you can "persist credentials" in the web part. This was designed for the initial logging in for the map, but it might also work for the Locate workflow (I haven't tested this, though). If not, let us know and we can add it as an enhancement request.Hope that helps,Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
drakefinley
We are using 3.0.  So im not sure if what you have said will help.  I thank you though.
KatherineDalton
Hi Drake,
You're correct, we don't have that functionality in 3.0, only in 4.0 Beta and above.
As for your original question, no, there is no way to "pass through" credentials at this time, but that is something that is part of our issue backlog.
Katy
