Problems with Sharepoint map at 0,0
11167
13
10-14-2022 12:11 PM
TimLohnes1
Was excited to have a list created from survey 123, then have a Sharepoint page with a map of the survey locations. I want to filter the list, but before I get there, my map loads at 0,0 and when I filter it zooms out, then zooms back to 0,0.
Why would my map be locked on 0, 0.
Attached are 3 images, 1. initial SP page load with map at 0,0. 2. list item selected and map still at 0,0 (though when selecting it zooms out first like it is going to zoom to filter selection, then zooms back in to 0,0) 3. Manually search for area and seeing that the list filter did work.
The filtering from list selection to map actually works, but after it repans to 0,0, I have to use the search for the city to get my polygon in focus.
Also, wondering if the Boards view will be able to do the filtering at some point. I know both the filter map from a list and Boards view are relatively new features.
Tim 
TimLohnes1
Raaj,
Same as you. I haven't found any way to limit the extents of the hosted layer.
Thought it might be something in Connect that set this view, but couldn't find anything in there either.
Maybe time to start over, see if a clean start works.
Thanks for taking the time. Much appreciated.
RaajRaaj
No problem. I am always here to help, if you have any questions on dynamic data or other features/functionalities in the app, please feel free to reach out to me.
Feedback/suggestions from users like you will immensely help us improve the product.
Thank you!
MTFAgain
Is there any plan to change this behavior (the fact that when filtered, maps zoom back to the extent of the data layers)? We have layers with correct extents set, but the actual extent is too large to be useable.
Can't the map please just stay put when the user filters data?
RaajRaaj
That has to be done at the time when the layer is created. In ArcGIS for Sharepoint you will be able to add layers from ArcGIS or data layers.
You can still set the visible range in ArcGIS for Sharepoint under "layer properties" after you add the ArcGIS layers and then you will need to share the web map containing the layer from ArcGIS for Sharepoint to your ArcGIS org. Let me know if I answered your question?
Raaj
