Mapit 1.1.1 Sharepoint 2007 no Datasource in Map Content
1524
03-15-2011 04:55 AM
HendrikLadewig
I've installed Mapit 1.1.1 on a 2007 Moss Enterprise and add a Datasource (Sharepointlist) in the Map Webpart.
In the "Modify"-View the Mapcontent available and the Items are displayed in the Geo- and Map-Webpart.
In the "normal" View, the Geo-Webpart has no Datasets available. Ive checked this with older Versions -> same result.
Whats the solution ???
LouFarho
After adding the data source make sure you click Okay in the web part properties pane. If you exit the editing mode in SharePoint without c.icking Okay or Apply, your setting will be lost.
HendrikLadewig
Thank you for reply, ive installed a new Server.
