Esri Sharepoint Web Part - Require Named Account to Edit?
1231
09-18-2017 06:45 AM
MaryEllen_Perko
Hi.  We would like to use Esri's sharepoint web part to allow users to edit spatial data.  I've been able to configure the web part to include editing capability, my feature layers are shared to everyone, but when in run mode, the edit tools are not available unless I sign in to ArcGIS Online.
Does anyone know if this is as designed or have I missed a configuration item?
Ideally, we'd like for users to edit the data without having to sign in to ArcGIS Online.
Thanks for the help.
AtsuhitoNAKANO
Hi Mary,
Hopefully I can answer your question:
The map part should be on "Guest Access" whether the page in run mode or not.
(If you see the map web part without signing in, so you should have configured to allow "Guest Access". is that correct?)
That behavior should be designed. Guests has limited access to only view map parts including public layers and sharepoint layers.
Configure ArcGIS Maps for SharePoint—ArcGIS Maps for SharePoint | ArcGIS
To use more functions, users need to sign in ArcGIS.
Atsuhito.
