Esri Maps for Dynamics CRM - fix a location?
3883
07-07-2015 01:37 AM
GertConradie
Hi
Would it be possible to fix a location 'manually' - as is available in Esri Maps for SharePoint?
Fix a location—Esri Maps for SharePoint | ArcGIS
Thanks!
Tags (1)
DanielLee2
Unfortunately this feature is not available in Esri Maps for Dynamics CRM. The only option would be to update the address and re-run the workflow. The geocoding workflow will be automatically be executed if the workflow is configured to run when the record is updated.
DanielLee2
GertConradie
Thanks
Would be nice to tweak a position if the geocoding get it wrong - a meter in or out of an administrative boundary if the location are used for further system/spatial integration.
Regards
