I have tried using the following country names to try and correct the error: DRC, DR Congo, The Democratic Republic of the Congo, Congo-Kinshasha. But nothing seems to correct the error. Anyone have a solution?
I beginning to think it is a problem with the ESRI MS Office plugin.
as note in the answer to your duplicate post, this is an error without an alternate solution
I am not using any plug in. I am just importing a csv file and am having the same problem. This seems like an easy fix - what name does the ArcGIS location tool use for Congo DR? Did you ever find a solution? You asked over a year ago.
