Symbology driven by Arcade code block fails in Field Maps
2681
12
09-17-2025 10:08 AM
AmyRoust
I've seen several posts that are similar to my issue, but no perfect matches. I have a line feature layer that is symbolized using an Arcade code block. The symbology works in Pro and in Map Viewer, but when you open that same web map in Field Maps, all of the lines default to the "other" symbology instead of matching what's in the legend. Are there limitations on Arcade-driven symbology in Field Maps? If it matters, I'm on Field Maps version 25.1.0, build 1141.
DiveshGoyal
Can you share the map with me so we can investigate? Feel free to DM me the details
DiveshGoyal
We have identified a fix for this issue. We will get it scheduled for an upcoming release in Q1 2026
AmyRoust
@DiveshGoyal - thank you for investigating and finding a fix! This will be a big help to us.
