Show custom message
813
04-03-2023 08:12 AM
BrianBulla
Honored Contributor
Is it possible to use Arcade to show a custom message once a feature is selected in the map?  For example, from the feature selected, I would like to show a message that indicates if there is any outstanding work that needs to be done (based on some business lgoic that would look at the related inspection records for that feature).
We are currently using ArcPad to do this, but with transitioning to Field Maps we are trying to replicate as much functionality as possible.
Thanks
DougBrowning
MVP Esteemed Contributor
Yes I do this a lot for our field data.  I actually tell them if they got all 12 forms done or not.  I can even do pattern matching so that it makes sure they did 1,2,3 not 2,2,3 for example.  I then use red to make it pop.
All done with FeatureSet just run a query like this.
var EvaluationID = Concatenate($feature.PointID, "_", text($feature.FieldEvalDate, "Y-MM-DD"))
var sql = "EvaluationID = '" + EvaluationID + "'";
var tbl = Filter(FeatureSetByName($map,"Water Quality and Macroinvertebrates", ['EvaluationID'], false), sql);
if (count(tbl) > 1) {
return "More than one form found"
else if (count(tbl) < 1) {
return "No forms found"
else {
return "1"
Hope that helps
