Setting Up Constraints in Smart Forms
650
08-04-2025 07:41 AM
CASSIEANGERER
Has anyone had luck setting up constraints in Smart Form for Field Maps? For example, I have two date fields that staff will enter. I want to make it so that the second date field must be after the first date field.
I know this can be set up in attribute rules and portal, but we only have ArcGIS Online, not portal.
RhettZufelt
MVP Notable Contributor
A couple options.  You can put either a visibility or editable expression on the first date field similar to.
!IsEmpty($feature.DateField)
This way, the second date field will either not even show in the form OR not allow anyone to edit it unless there is a value in the first date field.
R_
